With the new update update Fibaro added pin support for Danalock V3 lock. Anyone know what the use case is for this? Is this only relevant when using the lock with a dana keypad? Or is there a way to add a pin so user from Fibaro needs to add the pin to lock/unlock using z-wave?
Yes, only with dana keypad.
If it is paired with danalock it is possible to manage the pins using the hub now.
    ok, thanks for clarifying !
