zwbob 0
After the first of last 2 beta updates I experience the following problems:
- Smart Implant - When setup auto off duration it doesn't goes off i.e. the configuration of the parameter shows that it set to specific time but it doesn't turn off. Solved by using a scene with delay. Firmware of the smart implant 5.2. Previously included smart implants with set auto off time works perfectly.
- Walli plugs and Walli Switches - the ring colour, intesety etc. responds only in the parameter tab. When I try to change this parameters in scene, or tried to set it to go off for example from Settings/Profiles it doesn't respond at all. Before these 2 beta updates everything was working fine.
I waited for the stable version 5.150 tried the described above but it is still the same.
Boris
