WorthingtonD 0
We were having an issue where our Smart Implant was falling asleep and not reactivating unless we logged into the hub and reactivated it. The implant is connected to a low voltage port on an alarm panel to trigger INPUT1 as an analog input without pull-up resistor. It worked great if the implant wasn't asleep. I updated the firmware of the Yubii thinking it might help. Now, after re-configuring the implant in the hub, I can see that the implant did send the signal to the hub, but it doesn't trigger the scene. The scene is set to trigger at or above 1 volt. Was there any change in the firmware that would make a scene not fire? If you need more info, let me know. Thanks!
6 answers to this question
