Update breaks thermostat view in app
After update thermostats like MH7 or MH8 are not accesible anymore from the app. Tried both android and IOS.
If connected locally to the HC3 it works ok, but when using the remote connection (FIBARO cloud)  the thermostat plugin doesn't load.
Phone app is updated to latest version.
@A.Socha can you please verify ?
Thank you !
app 1.20 version?
    IOS 17.0.3 , Android 1.20
    thank you
    any news please?
    Thank you
    • 3 weeks later...
    I've discovered that we are facing this issue as well
    • 3 weeks later...
    Also have the same problem.
    try now. We made small update to solve this problem
    Please use 5.150 firmware to test it
    Tested but still fails. The Yubii app on IOS from remote access does not load thermostats or quick apps.
    Home Center 3 and a Yubii Home firmware version 1.150.18.
    Yubii app version 1.21.0.
    can you post how it looks?
    The same problem, I wrote about it on November 14.
    In 1.5 months, it still hasn't been resolved.😞
    @A.Socha, in this topic has an example of what it looks
     Please write more details.
    We tested on 5.150.18 with last app Yubii
    This happens to me also. I've noticed happening whenever I'm accessing outside my home network.
    HC3- Version: 5.150.18
    Yubii App - version: 1.21.0 (iOS 17.2.1)
    I've attached a picture of what I see when trying to load the plugin... just a blinking and increasing size dot.
    Edited by VascoFilipe
    @A.Socha, What other details are needed when it doesn't work?
    Write what exactly you want, I will write everything down in detail and do it if necessary.
    Any device that opens in the system as a plug-in (QA, heating and air conditioning thermostats, etc.) does not open in the iOS mobile application when connected through the cloud (outside the local network). On Android devices, it works but with an error (often, when the device is opened for the first time, the system interface is loaded)
    @A.Socha, Here is an example from a mobile application on an Android device
    Technical support has stopped responding to recent inquiries about this issue altogether
    P.S. When you are on the same LAN as the controller then everything works fine.
    Maybe didn't test correctly?
    @A.Socha, It is very good that you are aware of the problem🙂
    But is there any understanding of the time to solve this problem?😉
    For example, I cannot commission the object to the customer, since he cannot fully use the system remotely😕
    It would be good to have at least some understanding of the situation
    • 3 weeks later...
    Any updates on this issue? As we are using thermostat device for several projects and sites as well.
    HC3 version: 5.150.18
    Yubii App version: 1.21.0
    Edited by HA2016
    Уes everything works fine now
    I don’t know for what reason, but everything worked at some point (perhaps something was fixed in the cloud)
    We are still facing the same issue unfortunately :(
