jnathalia 0
I have several zones and normally I'm using the Fibaro external temperature sensor to make perfect settings for the temperature in the zone. Fibaro external temperature sensor communicates with one or multiple Heat Controllers of Fibaro and this is working fine.
Now, I have one zone with an external Z-Wave temperature measurer (MCHome) with 2 Fibaro Heat Controller thermostats. Is it possible to set the temperature while it's using another Z-Wave temperature measurer (instead of the Fibaro temperature measurer)?
Somehow, I haven't seen you can attach a temperature sensor to a zone. Setting it for a room it's possible...
If anyone has experience, please let me know. I'm just asking to consider buying more Heat Controllers without the Fibaro external temperature sensor. Thanks.
Edited by jnathalia1 answer to this question
