[SOLVED]iBlinds not working correctly after (re)adding
After the 5.150.15 update, I added a new iBlinds device. Adding the device works, it is however recognized as 'Blinds without positioning' whereas before it was 'Blinds with positioning'. Pressing the up/down button do not result in any action of the iBlinds. Even when changing it to 'Blinds with positioning', the slider and up/down does not do anything. In the HC3 I can set parameter 7 to '1' to force calibration, which is successfully received and done by the iBlinds, so the connection is working.
6 other iBlinds which were already added before the update, keep working correctly so it looks like it only occurs to device which are added after the update.
Any help / suggestions? Can I upload some device template of working + non working device so that somebody can check for differences?
Thanks!
Yes please, upload it here and we will check it out :)
    Missed the reply notification, so sorry for late reaction. That would be great, please find templates attached!
    On it, already forwarded to the developers.
    Thanks for the templates.
    • 4 weeks later...
    I have add new iblinds and have the same problem.
    No reaction when changing the position.
    I add them with firmware version 5.150.18
    Any news about this problem
    yes, it should be fixed :)
    A few minutes ago, a new beta was released.
    Reconfiguration should resolve this :)
    Aaah great. I updated to 5.151.47 (beta) and can confirm that all is working properly after reconfiguring the device.
    Thanks!
