Excluding devices does not work (zWave 3.0 engine).
Dear all,
Trying to exclude devices from my Homecenter, however, this does not work.
Issue was there as well in beta version 5.142, but seems to still exist.
Anyone else experiencing the same?
Any work around? Force remove does not work, as the system says there is no issue with the device (which is true).
regards Jeroen
@JeroenL
Curently I don't use ZW3 on my homecenters.
Things you can try:
Restart hc > reset the device you want to remove according to its manual > power down the device > start force remove the device
Turn off the power to the device and then try force remove, that should work.
