Climate panel in manual holding mode
When heating panel is on manual holding setting, I can't change the temperature.
For instance I try to change from 19.5 to 20°C, then press the Save button, but nothing happen, the temperature is still at 19.5 value.
/monthly_2023_11/MobileHeatingpanel.png.e93d38e54804320212eac241cf64d38a.png" />
@lazer Hi, I've just tested the same with one of my climate zones. Mine is working as expected with my android handy.
Things you can try:
-Check if you are on the latest software, 5.150 for hc and 1.20 on the yubii app.
-Restart hc and handy
    Thank you for your feeback
    Yes I am on latest versions for both the mobile app and the gateway
    And yes, I have also tried to restart app and HC3, many times actually...
    I also tried another climate zone and the problem still persists.
    Everything else is working, the only issue is when the zone is on manual infinite holding time (no schedule or vacation mode)
    @lazer  Press the synchronize button under: Settings > access > synchronize
    Do you use your yubii app as a normal user or the administrator?
    Local acces or remote access?
    What happens if you delete one of your climate zones and setup again? I also recommend to restart hc before the new setup.
    Edited by Fabir
    I use a normal user, only with local access.
    I will try the tests you suggest, and keep you informed.
    @lazer Now I've also tested with one of my local users and a climate zone. It reacts immediatly on the app and on the history panel.
    Go to the history panel on the controller and checkout if the changes are visible?
    Edited by Fabir
    Thank you for your help.
    I did many tests, and finally found the error... which was not in the app nor the HC3 controller, but in my reverse proxy.
    For the record, when I said that I use the local access, I am in fact using my public IP address through my domain name, and the whole thing is protected by a reverse proxy (HAproxy) which also performs some security checks (Apache + modsecurity)
    When you modify the manual temperature on any climate zone, the following request is performed :
    With the following data :
    Which triggers a strange "Looking for intiger overflow attacks, these are taken from skipfish, except 3.0.00738585072007e-308 is the \"magic number\" crash" error in modsecurity, then returns a HTTP 403 code.
    The issue was that this error is not displayed in the Yubii app, which simply closes the window without actually changing the target temperature.
    So I added a new rule in my whitelist, and everything is now performing smoothly :)
    Too much security sometimes creates strange results.... 😇
    Edited by lazer
    @lazer Thank you for the update. Cheers!
    • 3 weeks later...
    Hi
    I have HC3L with 5.140.17
    When I try to change something in Settings/Climate I get this message : "unable to update the zone"
    Any clue?
    @iTibor Update to the latest fw 5.150 and try again.
