PeterB 0
I want to create a report to check all the settings of my devices. Therefore I want to use a api call (api/deviceNotifications/v1).
Using this in a QuickApp I get every time the code:
I am sure that I have created the right Authorisation with
. Using this call with curl gives me json output.Am I not allowed to use an api call within Homecenter? Only outside? Do I have to change a setting so that I can use this api call? Basically what am I doing wrong?
my test code is:
