BallaBooYeaH 0
I must have an issue with my wiring. Connecting directly to a powee supply - the white strip works fine. I am wanting to use a RGBw2 module to be able to dimm the LED strip.
I looked like it is wired correctly but I cant get anything to work. Not sure if it is a settling or incorrect wiring.
Open to suggestions as to what else to try. I have used 2 different RGBW2 modules to check it is not the module
Also with this wiring trying to do a RGB strip, I can only get 1 colour Red. this is with one push button Mech and using the PC to change colour, I still can only get one colour to work.
Edited by BallaBooYeaHedit
11 answers to this question
