COV 0
I've connected 3 Heat Controllers to the same Temperature Sensor : External sensor is correctly "Connected" for each heat controller.
As you can see in the attached screenshot :
- the feedback about the temperature is slightly different from one heat controller to the other ;
- the feedback about the battery level of the temperature sensor is also different from one heat controller to the other.
How to explain that ? Is there a way to fix the issue regarding the battery level of the temperature sensor ?
Thanks for your help.
