Walli dimer + Standard switch
Hi everyody.
I have a problem installing a Walli dimmer into a 2-way swich
When I remove my Simon 72 swich I found that
/monthly_2023_12/image.png.979d53038aaeee2030a92436a82c9f8d.png" />
2 black cables into the wite plugs and a brown cable into the red plug.....
Anybody can tell me where should I put the cables into the Walli Dimmer? Maybe should I need an extra cable?
I think I tried all combinations and I can't make work the 2-way
Thank you very much
@Bitter You can't use a walli dimmer in a 2-way wiring.
You can use a walli switch in a 2-way wiring. But than you would have to pull a neutral to the walli switch.
Or use the fibaro dimmer 2 modul FGD-212. Lock below the for the wiring.
If this doesn't fit to your wiring, you can also checkout the vesternet.com blog.
    Ups I don't see that I CAN't use a Walli Dimmer
    Thank you for your support
    Edited by Bitter
