Custom param for electronic limit switches configuration?
I have a question regarding motors for blinds with electronic limit switches like the somfy j4wt. Basically the way to configure where the shutters have their upper and lower limit is to set the motor into configuration mode, and to do this you need to pass current to both Q1 and Q2 terminals at the same time (which normally would be a "no go" for a motor without electronic limit switches). I haven't found any solution for this in the manual, so is there a way to get it added to the software as additional parameter that can be set? Or is it impossible due to technical design?
