MCO Home MH7H-WH (v2.9) Template in HC2 4.630 (device parameters)
smprofx
I have recently bought several MCO Home MH7H-WH thermostats (v.2.9) and after inclusion in HC2 (sw: 4.630) there are no parameters displayed in the Advanced - Configuration area.
I have tried removing and re-adding the thermostat then also tried the soft reconfigure.
I can see several slave devices for related functions.
1. I'm asking the Fibaro tech support or community if there should be some parameters displayed here or still this MCO thermostats are not yet fully supported like other (ie: Fibaro) products?
Nb: Attached is the Template file downloaded from the device if it helps in any way for Fibaro to add support for this template.
Also in the manual I have found the following table related to the parameters but I'm not familiar how to manually add them in the device configuration.
2. For example how should I add / configure parameter 3: "Automatic Temperature Difference Reporting"?
Edited by smprofx
Hi @smprofx ,
First remove check for using template:
/monthly_2023_12/Usetemplatenot.png.ba682101473be3ddecbac605fd5272de.png" />
Then click on button Add Parameter and then in the row that show up fill in from left to right:
1) Number - parameter number, that is first left row on your screenshot showing MCO parameters
2) Data type - this is actually size(byte) e.g. for 1 you select 1d
3) Desired value - enter the required value, either default one or one you need.
4) Click on button Add Parameter to add next one and repeat unit you enter all parameters.
Save and if it is battery device then wake it up to finish.
Here is example of manually added parameters for Aeotec MS6:
  • Thank you @Sankotronic for reply.
    So If I understand correctly for parameter 3 "Automatic Temperature Difference Reporting" to be 1 degree i should write:
    Number: 3
    Data type: 4
    Desire value: 10
    .. correct?
    Hi @smprofx ,
    according to the picture of the parameters in your post for parameter 3 "Automatic Temperature Difference Reporting" to be 1 deg write:
    Number: 3
    Data type: 2 which on HC2 is 2b
    desired value: 10
