Hi Community
it is very nice to see all of these temperature Chats
like these:
It is good enough. (for me)
But is it possible to show also thr Humanty charts from the diveses ? I am seaching and searching but there it no buttom to switch the "Humanity or brightness" chart "on".
Is there a trick to switch it on ?
Hi christoph,
with humanity you mean humidity. I don't know how to create a humidity-chart like a temperature chart, there is definitely no "switch" you can use. The only way I know is to export historydata (Verlauf), but this is not plug and play.
Search (google) for grafana and influx. You may define your humidity sensor as temperature sensor, but that gives you no direct useable data like 50° is 50% and i even don't if it works with HC3.
I still use HClite for the reason of the graph ability.
Check this:
Hi
Awaiting for system solution, I made and published QuickApp with charts for many types of sensors, and also binary- and multilevel- switches (dimmers roller-shutters).
So all the graphs are available now also for mobile apps.
Details at the MarketPlace:
  • Like 4
