How can I find the timestamp when a variable was changed
Is there a way to find when a variable was last changed ?
7 answers to this question
api.get('/globalVariables/'.."myVar").modified
ex.
print(os.date("%c",api.get('/globalVariables/'.."myVar").modified))
Was just checking HC3 v5.150.18 Swagger and could not find globalVariables under the Select Definition. ;-)
Also can't believe that there is no function for that like hub.getGlobal("varName")
like on HC2 is fibaro:getGlobal("varName") or even better fibaro:getGlobalModificationTime("varName") 😮
I'm not surprised that @RohitNz had to ask about it here. Thanks @jgab for doing Fibaro job.
Fibaro, what is the use of "Game changer" box when it is missing proper manuals?
It's under /panels/globalVariables
hub.getGlobalVariable(name)
...and it turns out that hub.getGlobalVariable(name) returns modification time as second returned result.
Big thanks @jgab ,
It is time for me to get new glasses 🥸
@jgab how to use in ER5?
Hi @jgab ,
Can you please explain the select(2,..) part in above line.
I have tested this code and it doesn't work in scene:
but it works in Quick Apps.
Explanation of this function in
is at least not complete and in
is not mentioned even is working as expected??
35 minutes ago, Sankotronic said:
Hi @jgab ,
Yes, it's because they maintain 2 different implementations of the fibaro sdk (or hub). One for scenes and one for QAs...
It seems that the scene version of .getGlobalVariable(name) doesn't return the modification time as the second value. So for scenes you need to go back to the api
or redefine the function
So, select is a standard Lua function.
will return the parameters from i and forward (as multiple values), so
will return
So, in our case, fibaro.getGlobalVariable("A") will return
so our select(2,fibaro.getGlobalVariable("A")) will only give us the time that we then pass on to os.date()...
We could have written it as
but it is creating an unnecessary table and is much less efficient  and not the "Lua way" ;-)
