Hello, qiuckapp under heos works without problems.
The problem arises when we use declarations (Conditions/Triggers). We can't check if heos has been turned on.  Since it displays a given station when switched on, it could be a station displayed with a condition/trigger.
For example, louder, quieter I assigned to myself a keyphobe and a switch... When I hold it down, I turn it up or down and everything is ok... But only when I set a variable that will refer to turning on the radio. Only then can I set the volume. Otherwise, the volume works regardless of whether the radio is on or off. You can be quite surprised at five o'clock in the morning when you turn on the radio, which will be set to full by a child, for example; )
set start level volume in Denon?Heos?
    I managed with the voice through the variable. But the problem is that I can't ask the device if it's actually on. That's why it's based on a variable. I'd like to get feedback as per google home that will confirm the inclusion. Then I could assign it in conditions or triggers : )
