Automation light does not work in szenario
Hello everyone,
I have 3 lights in the garden that are controlled via radio receivers from Elero (Revio-868).
I would like to switch the lights on at 5 p.m. using a Time-Line scenario. The scenario works manually, but not automatically at the scheduled time.
Does anyone know how to fix this?
Thank you and best regards
Max
Do you have Revio-868 (284000006) or Revio-868 SW (284150006).
If you have the SW versions, which are correct for just switch a light on and off, they are a little "special".
I assume you have pressed "UP" for switching on and "DOWN" for switching off while binding.
What you can try is to invert the logic in the Revio device and try your scenario again. That worked for me.
Else you just can PM me if needed.
Make sure that manual mode is disabled for those devices :)
I have two Elero Revoline awnings, and a Home Center, Yubii Home.
For years it has worked, perfectly.
A few months ago, I don't know when, the scenes of extending the awning and retracting the awning didn't work, it didn't do anything.
However, if I activate the awning directly with the app or with the PC, dash board, it works perfectly.
Only the scenes don't work. I've tried redoing them, changing the logic, everything, and it's still the same.
When I look at the event history, the scene starts, I get the notification email, the event of; action open awning or close awning, but the awning device does not respond to whether it is closing or closed.
or be open, open
However, activating as I said from the app or PC, everything goes well.
I receive action open, opening, open, action close, closing, closed.
Perfectly.
Where is the problem?.
The manual operation option is disabled, and I have tried reversing the logic.
