Problem connecting to HC2 - not found in FIbaro Finder
Having problems connecting to my Fibaro Home Center 2 after it has been not used for app. 5 years.
I tried to connect with Fibaro Finder, no luck. I read a lot of manuals, nothing helps. What is the correct way of resetting it to a known IP adress for example? So that I can restart my experience with the Home Center 2.
Very grateful for any help.
@Beagles Hello and welcome to the community.
To change the ip from fix to static with the plus button look
The recovery Guide for hc2 is
