michalpop 0
Hi, I'm tired of constantly having to change all walli dimmers to switches. I've changed the light from normal to a led strip (9m - 9,6W per meter - 24v power supply 100W). That should exceed the minimum load? However I get flashing red after a few seconds of working led stips. Is there a way to make it work without the need of changing to switch?
I've disabled dimming in the parameters (using HC3). I have a few boxes of the bypass 2. No clue how to connect it? Is it on neutral cable before the power supply? I'm not good with the diagrams. Could anybody tell me how to put it together so I can understand?
