[HC3] QA options in select
i saw the new select in th QA and in the options you can set the name and its value
how can i know the value from the select bar.
thx
7 answers to this question
 I think the name to the left and value are locked toghter and the value is used to refer to that selection. corect me if I am wrong! :D
I got this somewhere on the forum to get to know how it works:
function QuickApp:myDropdownHandler(args, ON)
  self:debug("My selected item is: " .. args["values"][1])
if (args["values"][1] == "ON") then
self:debug("ON!!")
elseif (args["values"][1] == "OFF") then
self:debug("OFF!!")
else
self:debug("error!!")
Hope it helps :) It helped me to understand how it works
Edited by Brors94
    thx!
    args was the thing i seek.
    Works great when pressed. Then you get values. But is there a way to get standard de values of de select option you pick lick variables in the tab infront of the QA.
    self:getValiable("var")
    i want to set lightvalues that comes from the option.
    thx
    thx
    You want to map select options to your quickAppVariables?  I'm not sure I understand your question - can you elaborate a bit?
    So you want to read the selected value without the user having selected (when you get a callback with args[]) ?
    No, there seems to be no way to get the selected item like that.
    I recommend that when the QA starts it sets the initial select value and also stores it in a quickAppVariable or global variable.
    Then whenever the user selects something you update the stored value.
    This way you can anytime read the current selected item.
    Oke thx for feedback. Thats what i also thought.
