Module advise for led light
We recently moved house and I moved my Fibaro modules(and Home center 2) with me. In the old house, my FGS212 was driving one Philips aqualine 25W(see below) which worked fine. In the new house, we have a bigger garage and there are more lights connected:
2x
1x
The problem is that the light switch gets stuck in the "on" position because the relay sticks. When searching in this forum I saw more reports on this when using this with light lights containing electronics.
As this problem keeps happening and I can only fix it by ticking on the module with a screwdriver I'm thinking of replacing the Fibaro module with a new one.
For this, I have 2 options:
  1. Fibaro Dimmer 2 FGD212
  2. Fibaro Single switch 2 FGS213
All the lights are not dimmable, and because of this, I would prefer to use the FGS213. However, the manual, it does not specifically state it supports LED lights (however in other places of my house where I use the FGS213 it's not having any problems with LED lights). What would be the recommended module with the above 3 lights?
Edited by killer8
@killer8 I recommend the dimmer2 and use only the same model LED lights.
    Even when the lights are not dimmable at all?
    @killer8 The fgs-213 is not rated for LED load. You can set the dimmer2 to ON/OFF mode.
