tomasjacko 1
I am not electrician and I have house, where fibaro was made by previous owners.
At the hall, I have stairs wall lights (for night lightning). I wanted these to work with motion sensor and brightness but the brightness at the level 100% and 0% is almost same.
It also has bypass (because it wall always little bit lightning when everything was off).
Can someone help how to set brightness to lower points? I want to use these lights only for night with really low lightning.
Is the bypass problem? or it is problem of lights? it is LED lights
