Apple's shortcuts worked well with scenes from Fibaro, Fibaro/Yubii was always found with a new command. And suddenly the shortuts stopped working and Fibaro/yubii is no longer visible. Now I don't know whether this is after the latest update of Fibaro 5.150.18 or the latest iOS 17.
The smaller update to 17.2.1 did not solve it either. Are there others who experience this?
I am experiencing the same thing... So I am listening in on this.
    @Lisa,
    I think we are the only ones with this problem.
    Indeed, still working overhere.
    If you create a new shortcut or an existing one, will Fibaro be found? Not for me anymore, while this used to be the case. I could then select scenes from Fibaro, but they are no longer visible and existing shortcuts in the Fibaro section no longer work.
    same for me, and our customers, definitely not only ONE device / installaition issue
    • 2 months later...
    Guest MGf
    I have the same issue.
    Yubii app is not in the app list anymore.
    existing shortcuts work when manually started, but Siri doesn’t understand them anymore.
    hope there is a fix for this. Setting shortcut names as commands for Siri was a great feature to automate by voice commands.
    Unfortunately, after the latest updates from Apple, shortcuts Fibaro still do not work.
    Hello, with the new Yubii app and with the latest beta, the app appeared again in the shortcuts.
    I don't know if it's just me, I have no way of checking if it worked this way again for everyone.
    Greetings.
    /monthly_2024_03/image.png.39517eb0f556a3ab8c1cc43669265eab.png" />
    • 4 weeks later...
    Hello, I just updated the Yubii Home Center app to version 1.22.0 and the yubii home center app appeared again in the shortcuts.
    /monthly_2024_04/image.png.c1758f1641242aded579fcff5ac4c0c2.png" />
