scenes between Walli Switches and Walli Dimmers quite slow
michalpop
Hi, I have quite simple scenes between Switches and Dimmers (stairs). There is quite a delay (0.5 to 1sec) for the lights to turn on or off. Is that normal?
Declarations
conditions = { {
id = 206,
isTrigger = true,
operator = "==",
property = "state",
type = "device",
value = true
operator = "all"
Actions
hub.call(239, 'turnOn')
4 answers to this question
@michalpop I think this delay is about normal. For lighting in corridors and stairs, the scenes are often too slow.
You can try with associations, they don't involve the controller and therefore can react quicker. The manual for the fibaro walli switch is
@michalpop You're welcome.
Just keep in mind the following about assosciations:
only work between zwave devices nearby each other, with direct zwave connection
need to have the same security level or none
often only basic features are supported like ON/OFF
can't be temporarily stopped, you have to delete them
  • Yes, that is all I need. Simple on and off. Now there is 0 delay and everything works like a charm! so again.. THANK YOU!
    moreover.. now when HC3 is off.. the devices are still working just fine.
