set whole house climate to manual in scene
Hi
How can i set the whole house to manual in a scene and also how can i cancel this to set it back to what it should be please?
@Jay Ess I've setup one of my climate zones to go on manual for 30 minutes, in my case 24 celsius, every hour in the evening. After that, the climate zone goes back to the climate zone settings. You can set this up for one, or all of your zones.  Look below.
    thank you for the reply and the idea is good, but i wanted an override switch to enable me to put the boiler to "sleep",
    but made a block scene and then converted it to a lua scene to get the code to change the temperature as follows
    hub.climate.setClimateZoneToManualMode(3'Heat',"Hold"7nil)
    hub.climate.setClimateZoneToScheduleMode(5)
    need to test this to see if it works, but was actually looking how to replicate how in the front end under climate you can set the whole house to a set temperature, but it might be doing the same just looping through all zones?
    actually just tested this in a qa and it fails with ./include/main.lua:20: attempt to index a nil value (field 'climate')
    and line 20 is
    found the solution by using jgab functions
