PålW 0
I have a problem with specific devices disappearing from HC2. The devices are Qubino Flush Shutter DC and this has happened multiple times for the same room. I have four of these devices in total across two rooms and in one of the rooms both devices have disappeared on a few occasions and in the other neighboring room everything works flawless. I'm controlling the roller shutters via a scene controlled by a wall switch (fiber dimmer 2) and they are used daily however once the devices are gone there's no trace of them in the event log either. There are several powered fiber devices in every room.
Not sure why this is happening, if I try to enter fibarohost/fibaro/sv/devices/configuration.html?id=XXX manually Im returned to the device page of HC2. I haven't configured anything in HC2 when this happens.
The devices are about 12-15m away from the HC2 and it is not possible to add them in the room where they are installed so I need to move them closer to the HC2 even though I use system wide inclusion. If I try to add them where they are installed HC2 usually ends up in an infinite "Requesting neighbors" loop.
Edit: tested a restore from a couple of weeks back when one of the two qubino devices were already gone, the strange thing was that both devices now reappeared however none of them are responding.
Edited by PålW5 answers to this question
