HC2 ghosted devices?
I posted a couple of days ago about devices disappearing in HC2, something that might be related is that there might be "ghosted" devices in my system.
I've manage to re-add two roller shutters that have randomly disappeared from the system on a few occasions however I see some strange issues. The roller shutter was added as ID 472 today but the configuration process failed, I tried to reconfigure the device however for some reson the error "Reconfiguration process fails" appeared but with another device ID of 83, any clue why? This can be repeated. It might be so that this roller shutter had that device ID83 in the past however that device is not in the system anymore.
[19:22:52] ID 472: Unknown shutter position reported, please recalibrate it.
[19:24:02] ID 472: Configuration completed
[19:25:11] ID 472: Set parameter 78, value = 1
[19:26:12] ID 83: Reconfiguration process failed
[19:31:08] ID 83: Reconfiguration process failed
If I look at the notifications I se the device with the correct ID472 however if I press retry here it is again reported as ID 83 ([19:31:08] ID 83: Reconfiguration process failed) in the log, this can be repeated.
Try to delete ID 83 in Swagger, sometimes it will help.
If not perhaps helpdesk Fibaro
    Tank you for your tip however /api/devices/83 returns an empty page and I got a response code of 404 trying to delete it so I think it is somewhat more gone than that in the system but not completely.
    I moved the HC2 close to the qubino roller shutter devices and re-added them to the system, however these devices are left unconfigured. I put the HC2 in exclusion mode and pushed the button on the qubinos, the entries below are entered in the log but the devices remains, this can be repeated so it seem like something is off in the HC2
