Temperature Chart problems
Hi all,
I've got a strange problem with only one of my FIBARO "Heat Controller" valves.
The temperature chart is always empty, I think because the range shown refers to a wrong date (a lot in future - see picture)
A soft reconfiguration of device doesn't help.
Any suggestion to solve this problem? Is it a bug on gateway or it's about the valve. I'm using Yubii Home, latest stable version
Thank you
I also have issue with temperature charts. The temperature graph is rendered, however the setpoint is drawn as "OFF", and only after changing the timeframe to month or year it sometimes draws setpoint correctly, but then when coming back to shorter period it against draws the setpoint as OFF.
Attached is screenshot of 4 charts from single device, generated one right after another - day, week, month and again week.
The device is HC3L, with 5.151.47beta, but the issue occured also on the previous stable release.
Browser is Chrome 121.0.6167.87, both in regular and InPrivate browsing. But it's the same on Edge 121.0.2277.83.
i saw similar "error" with chart, when date was wrong, actually complettly different thermostats, 5 installed, one got for no clear reson wrong date and i had to reinstall it  to get rid of that (to not confuse customer)
Sure, when you click on * whiich is today/now, then you will see the chart properly.
I also use the google chrome browser for the fibaro controller.
When see this issue with the graphs, I delete the browser history, than it is ok again.
