Hello, i have a HC3 question about variables,
1) Is it possible to get a list of all QA variable's (and global variables / in lua by an api post)?
2) Can i delete variables within a QA (global and QA) by lua commands?
The way to delete is to set the value to nil
    Hey Jgab, thanks for the functions, that helps a lot!
    But after using the setQAVariable function with an empty or nil value the variable is stil visible in the list (with blank value).
    I want to remove the variable by lua code (like clicking on the trashcan in the variable list)
    Edited by Casa Domotica
    I'm confused, i have tried a lot of different methods for deleting QA variables from LUA (like the trashcan button) but nothing works.
    What is wrong with this?
        local info = api.delete("/devices/59/properties/quickAppVariables")
        self:trace("info = "..json.encode(info))
    The response is:
    "type":"ERROR","reason":"MISSING_PARAMETER","message":"id: missing required parameter"
    The response is:
    It's a bit more complicated - including the problem if you try to set the quickAppVariables list to the empty table...
    Exactly why api.delete doesn't work we can only speculate.
