Dimmer bright up using Aeotec WallMote Quad HC3
I had HC2 with VD that can bright up dimmer by 10% while i pressed button on Aeotec and decressed brightness by pushing another button.
Now i have HC3 and i have no idea how to implement this. Below is my working code. I have no knowlage about coding i done it with ChatGPT. For HC3 i cant figured it out
function getBrightness(deviceId)
  local brightness = fibaro:getValue(deviceId, "value")
  return tonumber(brightness)
function setBrightness(deviceId, value)
  fibaro:call(deviceId, "setValue", value)
function main()
  local deviceId = 1066
  local currentBrightness = getBrightness(deviceId)
  local newBrightness = currentBrightness + 10
  if newBrightness > 100 then
    newBrightness = 100
  setBrightness(deviceId, newBrightness)
main()
this was a topic I thought I could assist in but I cannot seem to get the code to function.
I am trying it with a Fibaro Button and whenever i push it TWICE a want the light to dim up in 10 steps up to 100 and then step back down to zero
I added this as trigger:
then the action:
I am getting issues with reading the current value and if I remove that function I still get errors on setValue with either nothing happening or nil returned etc.
Perhaps I should record the last state of the light to a global variable instead?
Edited by Whswede
