Hi jan,
Can I write something like this and then call this function for each device?
or can you better explain provided above 'transformer'?
    The function Event:_transformEvent(type, fun) is a built-in function where you can register your own event transformers. To allow type 'device' to have an id that is a list of deviceIds there is a transformer registered for that. You can register your own for 'location' that does a similar thing, as my example show.
    However, you can also do as you suggest, having your own function that registers a handler per device.
    Efficiency wise, it's equal.
    In fact, Event:_transformEvent(type, fun) does something similar to your function, by registering a handler per returned event - only advantage is that it's generic.
