try to change order
to
19 minutes ago, marczu_83 said:
try to change order
to
alright i will test in 15 min here, i did not know the order had a impact
it is correct that the order seems to make a difference and the code proceeds.
however i am gettng an error again due to something in the Lua2 code i guess.
sorry for the mess but i am truly quite new at this and to be honest Neato has quite the security compared to other api :-)
[08.11.2024] [11:25:18] [TRACE] [QUICKAPP53]: UIEvent: {"values":[],"eventType":"onReleased","elementName":"button_ID_2_1","deviceId":53}[08.11.2024] [11:25:18] [DEBUG] [QUICKAPP53]: ./include/sha2.lua:1551: bad argument #1 to 'gsub' (string expected, got nil)[08.11.2024] [11:25:18] [ERROR] [QUICKAPP53]: QuickApp crashed[08.11.2024] [11:25:18] [ERROR] [QUICKAPP53]: Unknown error occurred: handleJsonRpc
alright i found out that issue, seems to be the copy past on the signature issue, we are now on line 22 that is failing again which is the authorization.
[08.11.2024] [11:32:46] [DEBUG] [QUICKAPP53]: ./include/Neato_Robot_Info.lua:22: attempt to perform arithmetic on a string value
                ["Authorization"] = "NEATOAPP" + " " + signature,
currently stuck on the Authorization part pffff
whatever code i try i keep getting a 404 message at the moment, anyone any advice ?
function QuickApp:getrobotinfo()
    local robotserial = "XXXXXXXXX"
    local robotseriallow = string.lower(robotserial)
    local robotsecret = "XXXXXXXXXXXXX"
    local date = tostring(os.date("!%a, %d %b %Y %X GMT"))
    local body = '{"reqId": "77", "cmd": "getRobotState"}'
    local string_to_sign = robotseriallow .. "\n".. date .. "\n" .. body
    local signature = sha.hmac(sha.sha256, robotsecret, string_to_sign)
    local binary_hash = sha.hex2bin(signature)
    local base64_hash = sha.bin2base64(binary_hash)
    self.http = net.HTTPClient({timeout=5000})
    self.http:request("https://nucleo.neatocloud.com:4443/vendors/neato/robots/OPS02217-985DADC5A1BA/messages", {
          options = {
              data = json.encode(body),
              method = "POST",
              checkCertificate = false,
              headers = {
                ["Accept"] = "application/vnd.neato.nucleo.v1",
                ["Content-Type"] = "application/json",
                ["Date"] = os.date("!%a, %d %b %Y %X GMT"),
                ["Authorization"] = "NEATOAPP" .. " " .. signature,
          success = function(response)
              self:debug(response.status)
              self:debug(response.data)
          end,
          error = function(message)
              self:debug("error:", net.HTTPClient, message)
1 hour ago, marczu_83 said:
try to change order
to
thank you for the tip but it seems i hit the 404 error now hehe , something wrong with the way the Authorization header is formed i guess cause when i mingle there the errors differ
seems that if changed the Authorization to it accepts, however i am now facing the missing host part for some reason that is also not documented.
i added the Host Header but then i keep getting a 401 error for the moment.
any idea ?
["Authorization"] = "NEATOAPP" .. signature
host part was due to some internet connection issues, the issue still stays at a 401 error.
is the coding to bash_64 needed to perform the hmac256 ?
i think something is wrong with the signature as i tried to print all the value's and they seem to be responding correctly.
anyway to have a more complete log ?
No, its not necessary, you should check your api documentation to check how to create token,
code that you used is from switchbot api,
Hi Marc, i did study it for nearly months which is why i came here cause i can get thingd to work on commandline and postman, just not in fibaro lua so i need some genius of someone cause it should be a small thing that is wrong at this point. 😅
Under the Nucleo authentication scheme, the Authorization header has the following form:
Following is pseudo-grammar that illustrates the construction of the Authorization request header. In the example, \n means the Unicode code point U+000A, commonly called newline.
A Ruby example to compute the signature is as follows:
Authenticating with an invalid Authorization or Dateheaders will return appropriate errors with a JSON response in the format:
try
and
change to
Edited by marczu_83
2 hours ago, marczu_83 said:
try
and
change to
i just tried as i think this was a good suggestion but it is still giving me an error 401, which i think means there is something wrong in the authorization header or calculation of it.
current error:
09.11.2024] [16:35:01] [TRACE] [QUICKAPP53]: onAction: {"args":["onReleased","button_ID_2_1"],"actionName":"UIAction","manual":true,"deviceId":53}[09.11.2024] [16:35:01] [TRACE] [QUICKAPP53]: UIEvent: {"eventType":"onReleased","values":[],"deviceId":53,"elementName":"button_ID_2_1"}[09.11.2024] [16:35:01] [DEBUG] [QUICKAPP53]: onInit[09.11.2024] [16:35:02] [DEBUG] [QUICKAPP53]: 401[09.11.2024] [16:35:02] [DEBUG] [QUICKAPP53]:
this is the current code i am testing with :
self:debug("onInit")
    local robotserial = "OPS02217-985DADC5A1BA"
    local robotsecret = "A4A5B85AF336F2E7B3876DED5AC4A5F4A"
          options = {
              data = body,
              method = "POST",
              headers = {
                ["Date"] = date,
                ["Authorization"] = "NEATOAPP" .. signature,
                --["Host"] = "nucleo.neatocloud.com:4443",
          end,
              self:debug("error:", message)
try
and
change to
Glad to say we are successfull !!!!!!!!
the issue was indeed in the authorization header :-)
by changing the code to contain the correct amount of spaces it works !
working code below. :-)
    local robotsecret = "A4A5B84AF346F2E7B3876DED5AC4A5F4A"
          options = {
              data = body,
              method = "POST",
              headers = {
                ["Date"] = date,
          end,
Hello.
I also needed HMAC_SHA256 in a scene, so I managed to create implementation of the algorithm which works on HC3
I hope it helps you.
Edit: deleted copy of the code from my answer because it was taking too much space.
Edited by Wojtekb30
