videovox 0
Hello everybody. I am a begginer in LUA programming. I tried to make a QA which reads a voltage value from a Fibaro implant (which measures the voltage on a pressure sensor), use a formula which calculates the pressure from the voltage, displays it on the same QA device and make it available to other devices for use.. The voltage is read, the pressure is correctly calculated, but it is not displayed on the QA device. It stays always zero...
This is the QA I've done, please help:
