Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. New process for adding devices in the mobile app
From now on, users can more easily add their devices to the system via the mobile app using the new addition wizard. To use the new way of adding, install the new mobile application.
2. Changes for the new mobile application
App Store:
Google Play:
  • Added new default icon sets for devices, scenes, and rooms.
  • New way of displaying Quick App’s content.
  • Possibility to use Quick App’s old style view for backward compatibility.
  • New look for Sonos and Husqvarna plugin.
  • New design for user scenarios.
What's new:
Devices
    Corrected the display of values for the device available updates counter.
    Removed unused roles for baseShutter and rollerShutter types.
Nice*
    Added support for automatic calibration for BiDi-Shutter and BiDi-Awning devices.
Other
    Improved error handling when adding a user template for a device.**
Z-Wave
    Added support for devices:
  • ZVIDAR Z-TRV-V01
  • NICE Warm-Control
  • NICE Clima-Control
  • NICE Fan2-Control
  • NICE Fan4-Control
  • MCO OS11/OS12 for US and ANZ frequencies
    Stability improvements.
Bug Fixes:
Climate
    Fixed display of names for selected thermostats on selector.
Devices
    Saving of the slats angle in the favorite position for the FGR-224 has been improved.
    Fixed the appearance of the modal window for adding custom icons for multistate devices.
Gateway connection
    Fixed status display and the problem of the Master gateway not restarting automatically after the upgrade.
Linked devices
    Hysteresis settings for temperature and humidity have been improved - from now on it cannot be greater than the difference between the minimum and maximum values.
    Style improvements for Linked Devices – Choose Master device option.
Nice*
    Optimized handling of battery operated devices.
    Network performance improvements.
    Nice polling interval restores to default value after disabling it.
    Fixed support for parameter 5 of the BiDi-Shutter device.
Other
    The appearance of the notification list after using the "Clear all" option has been improved.
    Fixed problems with changing the order of rooms in the interface.
    Fixed the problem of the login screen appearing in the interface after using the option to restore the gateway to factory settings.
Quick Apps
     Support for long button press in Quick App.
Scenes
    Fixed non-working energy consumption block in block scenes.
    Fixed translations for some of the devices in the blocks.
Users
    Improved assignment of devices for users in case of empty sections in Access Management.
    Fixed the functionality of granting access to remote actions for the Installer in specific cases.
Z-Wave
    Fixed the default role setting after adding the FGRGBW-441device.**
    Fixed the update from version 25.25 to 27.27 for the FGRGBW-441 device for KR frequency.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
