Some QA's don't work (5.153.120)
QA for Philips Hue not working after update. I also have some other QA that don't work anymore.
In new Yubii app, QAs that are not actors, are not supported at this moment.
    They disappeared from the old Yubii app too!
    In this case it is not app version related.
    1.  Are you logged in admin account? If not, have you shared the access to the device?
    2. Are you sure the device is not hidden, or the room that it is in, is not hidden?
    3. If everything is checked fro above, try to clear cash of the app in the mobile phone, and re-open the app.
    4. If nothing helps, this is probably a case for support.
    That is actually really strange, is this checkbox is disabled for backward compatibility?
    /monthly_2024_02/image.png.42a27a6a6459f5466001ad44f14e981c.png" />
    And are you sure that it is about the quickapp? Not a plugin?
    Thanks. The checkbox for "Use the new views in mobile application" was enabled. After I disabled it, my QA is back in the old app. But Philips Hue plugin don't respond in either new or old app.
    /monthly_2024_02/image.png.9c3bb882294a3a421e2b431383203840.png" />
    Edited by Morten22
    about that, sorry - we missed one thing there.
    Fix for plugins is in progress, there will be soon 5.154 beta available with fixes.
    • Thanks 2
    New app (2.0.2) is in the stores.
    All QuickApps are visible now, if there is a problem with displaying content (due some html usage for example) make sure to disable new views in settings of the QA inside the web interface.
