the update completely broke my qubino measurements, soft reconfiguration changed the id, remove id, negative values for photovoltaics indicate zero. I have to go back to the stable version and hope that it will be fine in the next one. Otherwise, after 10 years of using fibaro hc, I'm really considering switching to Homey.
We changed the model some time ago (5.150 GA version if I remember correctly), there are no negative values on meters anymore (and won't be in the future) - you get meters for production and consumption (separate tiles) with different "rate type".
It is an evolution, you cannot expect that we won't change something in time when it does not work well enough at the start.
    I'm working on it right now and I understood the essence of the change, everything is fine.
    Great that it is clear now :)
    Marking as resolved.
