do
local p = print
function print(a,...) if a~='onAction: ' then p(a,...) end end
This QuickApp function stopped working after the last update, so now I have a lot of trace output in the console window. Is there another workaround to hide the onAction output?
I don't think a quickapp should stop working after an update. Better way is to look at the quickapp why it stopped working.
43 minutes ago, Sagittarius said:
do
local p = print
It's moved to QuickApp.trace
Try
    Thank you that worked :)
