Has stopped working, after this update... this they allso a new code for this, in this version?
id = 694,
isTrigger = true,
operator = "match",
property = "centralSceneEvent",
type = "device",
value = {
keyAttribute = "Pressed"
Edited by Sagittarius
This trigger is definitely invalid, in 5.150 GA and 5.153 beta correct trigger for central scene looks like this (exact copy from the system):
  conditions = { {
      id = 21,
      isTrigger = true,
      operator = "==",
      type = "device",
      value = {
        keyAttribute = "Pressed",
        keyId = 1
  operator = "all"
    Thank you... found a solution:
    id = 694,
    isTrigger = true,
    operator = "!=",
    type = "device",
    value = {}
    Now my code works again
    local trigger = sourceTrigger
    local ID = trigger.id
    if trigger.value.keyId == 1 and trigger.value.keyAttribute == "Pressed" then
    elseif trigger.value.keyId == 1 and trigger.value.keyAttribute == "HeldDown" then
