In the chanelog i can see, that MCO IR2900 should be supported in new beta
However, there is no support (no templeate), and on the other hand, temperature values are completly wrong, and inconsistent.
Anyone, any clue, what tot do with this? Is it a Fibaro bug, or MCO bug?
I have reported this to MCO too..waiting for the answer,meanwhile some Fibaro developer can assist a little bit here?
Do you add it one more time or force reconfigure?
    no
    In new beta you need to add it again or reconfigure.
    I did it right now,,,same nothing changed
    There are few different FW versions of it on the market.
    We got few samples, maybe not the right one for you.
    Paste here the template, I will check.
    Here you have...but i doubt, this is FW related, as the AC endpoint is working nicely, it is just the temperature sensor..Please check on this..thanks
    Edited by Neo Andersson
    well, but you have indeed different fw and product ID version than the supported,
    yours
            <basicClass>04</basicClass>
            <manufacturerID>015F</manufacturerID>
            <productType>2900</productType>
            <productID>7102</productID>
            <zLibraryType>03</zLibraryType>
            <zProtocolVersion>07</zProtocolVersion>
            <zProtocolSubVersion>10</zProtocolSubVersion>
            <applicationVersion>02</applicationVersion>
            <applicationSubVersion>0C</applicationSubVersion>
    supported
            <productID>7101</productID>
            <zProtocolSubVersion>12</zProtocolSubVersion>
            <applicationVersion>03</applicationVersion>
            <applicationSubVersion>00</applicationSubVersion>
    should this mean, that temperature reports can be incorrect?
    This will be a problem with the device firmware, not hub side.
    We are just showing the temperature which we get from the module, we are not doing anything specjal here.
    Template or not, it will be the same.
