QNAP management from HC2 to HC3
Good morning,
I'm switching from HC2 to HC3, I have this VD on HC2 to turn on my QNAP NAS, I would like to transfer it to HC3, what should I do? sorry but
Everything seems different to me, I attach the program
/monthly_2024_03/image.png.d9f2e3b6adedb87e3095045098a3016e.png" />
Accendi:
%% properties
%% globals
-- Wake On Lan v 1.0.0 [02-2013]
-- Copyright © 2013 Jean-christophe Vermandé
-- convert MAC adress, every 2 Chars (7-bit ASCII), to one Byte Char (8-bits)
function convertMacAddress(address)
  local s = string.gsub(address, ":", "");
  local x = "";  -- will contain converted MAC
  for i=1, 12, 2 do
    x = x .. string.char(tonumber(string.sub(s, i, i+1), 16));
  return x;
fibaro:log("Start process");
local _selfId = fibaro:getSelfId();
-- MAC adress
local _macAddress = convertMacAddress("00:08:9b:cd:66:d4");
-- Create Magic Packet 6 x FF
local _magicPacket = string.char(0xff, 0xff, 0xff, 0xff, 0xff, 0xff);
-- Broadcast Address
local _broadcastAddress = "255.255.255.255";
-- Default port used
local _wakeOnLanPort = 9;
fibaro:sleep(750);
for i = 1, 16 do
  _magicPacket = _magicPacket .. _macAddress;
fibaro:log("Magic packet successfully created");
fibaro:sleep(1000);
socket = Net.FUdpSocket();
socket:setBroadcast(true);
local bytes, errorCode = socket:write(_magicPacket, _broadcastAddress, _wakeOnLanPort);
--check for error
if errorCode == 0 then
  fibaro:log("Successfully sent");
else
  fibaro:log("Transfer failed");
-- clean up memory
socket = nil;
fibaro:sleep(1000);
fibaro:log("Please wait for the server startup.");
Spegni:
if (not QNAP) then
  QNAP = {}
   QNAP.qnap_ip = fibaro:get(fibaro:getSelfId(), "IPAddress");
   QNAP.port  = fibaro:get(fibaro:getSelfId(), "TCPPort");
   QNAP.globalvariable = ""
   -- Obtient le XML et le retourne sous forme de table LUA
   QNAP.getTokenFromXml = function()
    local QNAP2URL = Net.FHttp(QNAP.qnap_ip,QNAP.port);
    response = QNAP2URL:GET("/cgi-bin/authLogin.cgi?user=admin&plain_pwd=17Pa$$wOrd&remme=1");
    xmlTable = QNAP.iif(response ~= nil, QNAP.newParser().ParseXmlText(response), "");
    if (xmlTable.QDocRoot  ~= nil) then
      qsidstr = xmlTable.QDocRoot.authSid:value();
      if (string.len(qsidstr)>0) then
        fibaro:debug("Qtoken founded");
        qsidstr = qsidstr:gsub("[".."<![CDATA[".."]", '');
        qsidstr = qsidstr:gsub("[".."]".."]", '');
        qsidstr = qsidstr:gsub("["..">".."]", '');
        fibaro:debug(qsidstr);
        response = QNAP2URL:GET("/cgi-bin/sys/sysRequest.cgi?subfunc=power_mgmt&count=0.1234&sid="..qsidstr.."&apply=shutdown");
        if (string.find(response, "OK")) then
          fibaro:log("Power Off Server")
        else
          fibaro:log("ERROR")
   -- Teste la condition  et retourne la valeur true ou false
   QNAP.iif = function(condition, iftrue, iffalse)
      if (condition) then
         return iftrue
      return iffalse
   -- Ceci est une version modifiée par Steven de Corona-XML-Module par Jonathan Beebe qui a son tour
   -- est basée sur Alexander Makeev's Lua-only XML parser .
   -- see https://github.com/Cluain/Lua-Simple-XML-Parser
   QNAP.newParser = function()
      parseXml = {}
      parseXml.FromXmlString = function(value)
         value = string.gsub(value, "([%x]+)%;",
             function(h)
            return string.char(tonumber(h, 16))
             end);
         value = string.gsub(value, "([0-9]+)%;",
             function(h)
            return string.char(tonumber(h, 10))
             end);
         value = string.gsub(value, "'", "'");
         value = string.gsub(value, ">", ">");
         value = string.gsub(value, "<", "<");
         value = string.gsub(value, "&", "&");
         return value;
      parseXml.ParseArgs = function(node, s)
         string.gsub(s, "(%w+)=([\"'])(.-)%2", function(w, _, a)
             node:addProperty(w,  parseXml.FromXmlString(a))
         end)
      parseXml.ParseXmlText = function(xmlText)
         local stack = {}
         local top = parseXml.newNode()
         table.insert(stack, top)
         local ni, c, label, xarg, empty
         local i, j = 1, 1
         while true do
             ni, j, c, label, xarg, empty = string.find(xmlText, "<(%/?)([%w_:]+)(.-)(%/?)>", i)
             if not ni then break end
             local text = string.sub(xmlText, i, ni - 1);
             if not string.find(text, "^%s*$") then
            local lVal = (top:value() or "") .. parseXml.FromXmlString(text)
            stack[#stack]:setValue(lVal)
             if empty == "/" then -- empty element tag
            local lNode = parseXml.newNode(label)
            parseXml.ParseArgs(lNode, xarg)
            top:addChild(lNode)
             elseif c == "" then -- start tag
            table.insert(stack, lNode)
            top = lNode
             else -- end tag
            local toclose = table.remove(stack) -- remove top
            top = stack[#stack]
            if #stack < 1 then
                error("XmlParser: nothing to close with " .. label)
            if toclose:name() ~= label then
                error("XmlParser: trying to close " .. toclose.name .. " with " .. label)
            top:addChild(toclose)
             i = j + 1
         local text = string.sub(xmlText, i);
         if #stack > 1 then
             error("XmlParser: unclosed " .. stack[#stack]:name())
         return top
      parseXml.newNode = function(name)
          local node = {}
          node.___value = nil
          node.___name = name
          node.___children = {}
          node.___props = {}
          function node:value() return self.___value end
          function node:setValue(val) self.___value = val end
          function node:name() return self.___name end
          function node:setName(name) self.___name = name end
          function node:children() return self.___children end
          function node:numChildren() return #self.___children end
          function node:addChild(child)
         if self[child:name()] ~= nil then
             if type(self[child:name()].name) == "function" then
            local tempTable = {}
            table.insert(tempTable, self[child:name()])
            self[child:name()] = tempTable
             table.insert(self[child:name()], child)
         else
             self[child:name()] = child
         table.insert(self.___children, child)
          function node:properties() return self.___props end
          function node:numProperties() return #self.___props end
          function node:addProperty(name, value)
         local lName = "@" .. name
         if self[lName] ~= nil then
             if type(self[lName]) == "string" then
            table.insert(tempTable, self[lName])
            self[lName] = tempTable
             table.insert(self[lName], value)
         else
             self[lName] = value
         table.insert(self.___props, { name = name, value = self[name] })
          return node
      return parseXml;
QNAP.getTokenFromXml();
