Fail to get 5.150.18 to 5.154.37 (beta)
Guest Jasper Waale
The update was not performed due to an incorrect system image verification. If the update was performed manually through the system Recovery, please ensure that the correct version of the system was used.
So this not in production as I'm using a HC2 and the move is final to HC3 I read, but it failed doing the software updates and I have done full reset 2 times now, is the units that just turned on today broken
Im so happy I did not to the migration for now
Guest Jasper Waale
    Ok, I will anwser this myself.   New HC3 even with RJ45 plugged in and working DHCP looks to have WIFI enabled with no Setup and it messed up the download,  Dont have WIFI enabled
    if RJ45 is on just a tip
