HC3 LUA Script mit HMCO Home Switch
reto6004
Hey team, I'm at my wits' end 🥴. Actually, the task seems pretty straightforward (at least with LUA and HC2), but well, here we are. So, I've got a Fibaro RGBW Module and a 4-channel MCO Home Switch. Both devices are integrated and can be controlled without any issues. For starters/testing, I'm trying to create a simple LUA scene that turns on the LED of the RGBW controller to a predefined value when switch 1 of the MCO switch is turned on, and turns it off when the MCO switch is turned off. Somehow, I seem to be getting no feedback from the MCO, meaning when I press the MCO switch, it lights up green, but in the HC3, it appears as turned off. The opposite works brilliantly; when I turn on the MCO switch in HC3, it lights up green and is also active in HC3. Can anyone sweeten my weekend with some help?
Cheers,
Reto
Edited by reto6004
translation
