Which module to make a presence detector smart
Hi!
I have about 30 fibaro modules (switches, dimmer, rollershutter, smart modules) running with an aeotech Z-Stick as a gateway and homeseer as software.
Now I want to make a presence detector smart.
I already have tried a single switch only connected to S1, N and L. When the presence detector sends power to S1, the swith turns Q on (which is not connected to anything), but will not tell homeseer that the state has changed.
Do I have to use another module or is there a way to make the single switch tell homeseer its state?
If I am not mistaken You need to activate scene activation. Parameter 28. Default it is not active.
I do this with a standard (not smart) outdoor light sensor to trigger entrance- and garden lights.
Edited by Whswede
