self:updatelabel only works in Quick:init()
after the update i can only update labels in Class Quickapp:init()
if i try any other class i get error.
[ERROR] [QUICKAPP274]: no static 'viewCache' in class 'QuickApp'
You don't show us how you call it but I suspect you call QuickApp:ullern2() or QuickApp:updateView(...)
Ex.
You need to call your QuickApp methods using self:
QuickApp is a variable pointing to the class, in this case lacking the value 'viewCache'.
self is a variable pointing to the instance object, that in this case has the value 'viewCache'
    Yes i see now that it was my own fault, thought it was since i updated to new firmware.
