Can't remove roller shutter device
Good morning to everybody.
I have an issue with one roller shutter 3 device.
I'm trying to remove the device with force remove and not with exclusion mode (see next photo).
/monthly_2024_03/image.png.95956b2c785db85ecbdfd5d40e675214.png" />
But it keeps saying the above error. Any help is appreciated.
4 answers to this question
@assosboy Trough the force remove process, the hc3 will try to communicate with the rs3. If this is successfull, it will not remove the device.
Therefore I suggest the following:
Restart hc3
Try to exclude the rs3 from hc3 with the standard steps.
If no success, reset the rs3.
Power down the rs3
Try the force remove process on hc3.
    Restart hc3
    I haven't done this. I will try it.
    I've done this, but the device is not erased.
    I will try this.
    Power down the rs3
    I will try this.
    Thanks for the reply. I will let you know.
    @assosboy Do it step by step. From top to down.
    I reboot HC3 and roller shutter 3 device disappeared.
    Thanks for your help @Fibar
