Scene dely, on HC3 but worked fine on Hc2 , used to turn off 10 things at night
Guest Jasper Waale
I have a Scene that is made to turn off all lights and close curtains etc.  a total of 10 Items that need to have action
I do not test if on or off etc just do the events that need
I tested both as Block and Lua , and both have the same issue it's slow and looks to get stuck, some 40-60sec before the first action
Do HC3 add a delay or some delay for each line?   how to speed this up?   it worked well on my HC2
  conditions = { {
      id = 353,
      isTrigger = true,
      operator = "==",
      property = "centralSceneEvent",
      type = "device",
      value = {
        keyAttribute = "Pressed2",
        keyId = 8
  operator = "all"
hub.call(81, 'turnOff')
hub.call(262, 'turnOff')
hub.call(266, 'turnOff')
hub.call(344, 'turnOff')
hub.call(482, 'close')
hub.call(600, 'turnOff')
hub.call(602, 'turnOff')
hub.call(537, 'turnOff')
hub.call(541, 'turnOff')
hub.call(444, 'turnOff')
Hi @Jasper Waale ,
it is actually good practice to check current state of the device and then send command only if it is necessary. If you still want just to send commands to the devices regardless of their state it is good practice to add a slight delay between each command not to overflow z-wave network and give gateway time to process responses from devices.
