I added a remotec zxt-120 , interview hangs then when setting parameters it try to communicate with wrong id.
New device the remotec have id 338 but it tries setting parameters for 337.
Happens evertime that you exclude and include, fibaro tries to communicate with id - 1
Also cannot reconnect after soft reset properly due to wrong id.
    Edited by mike79
    Hi @mike79 ,
    ID 337 is the master device for included ZXT-120 and it is hidden in the system. It is not strange that HC3 is actually communicating with master device for changing parameters. Is it maybe possible that you are sending wrong value for the selected parameter and that is why there is no expected response?
    Something weird is going on, even switched back to default values, does the same thing it just doesn't seem to find the device anymore and i cannot wake the device up after softreset
    I added the remotec zxt-600 and that did not have any trouble ,it did not gang under inclusion and work flawlessly.
    it could be that it works since it is Z-Wave Plus and the 120 is not
