I am looking for the way to read a sensor connected to a ESP12 + ESPHome with a HC2 scene
The http request is
  When I try it with a browser, I get the string in whitch I can find the temperature.
How can I do with my HC2 to read the temperature?
Guest Theo
I process the data from a P1-meter so here is only the principle in its simplest form:
The HandleData function has to be written by yourself (within the same scene). Here the most basic example only confirming that data have been retrieved. I write them into Global Variable tables and remove the oldest entries after a number of days. Then I can use a Zerobrane Studio based script on my pc to import the data from my Fibaro.
    Hello Theo,
    many thanks for your answer and your help.
    Is this the code for HC2 or HC3?
    Best regards
