1. Working on a quiet large quickapp (>1000 lines of code, HC3) I've make a stupid mistake: some functions has at his end setTimeout command. This functions are used to update interface, registering some operations and so on. At the other hand - I invoke some of the functions to update interface "on demand". As a result more and more timers was set by setTimeout, and a "timer leak" occurs... Nothing bad happened, I correct this mistake.
My question is: how many timers can be set? Is there a limit of them? And is it possible to retrieve in QA information about already "ticking" timers (how many, time remaining, code to execute etc).
2. As I know in general Fibaro is asynchronous. But maybe some built-in function is and other is not?...
if on example we have the following:
and in the next few lines we test the value 'a'. After few millisecond, there's no guarantee that hub.getValue() answers until tested. Is such test unreliable? And to what value 'a' is initialised?
If correct how to protect from such situations - when I need to do something with received value at once?
Of course getValue is only an example. It can be also hub.call(....) and then test some property and many more.
3. Is there any differences between calling hub.function() and fibaro.function()? For me it working the same way...
4. What is the difference with scope of the variable in QA:
For me the scope of v1, v2, v3 is the same. Can someone explain a practical difference between those three definitions?
Thank you in advance.
In this post I started a million setTimeout - it took 41s for the last the finish.
There is no standard way to see how many timers you have. You can redefine setTmeout and clearTimeout to keep track of timers.
Ex.
getValue is synhronous.
In general only setTimeout, setInterval and the various callbacks from net.* functions are asynchronous.
When you press a button and your QuickApp:button() function is called or when someone call your QA with fibaro.call(YourQAid,...) it is an "asynchronous" callback into your code/QA.
We can argue then if fibaro.call is asynchronous as it doesn't wait for the call to complete before continuing (except sometimes checking if it is a valid call) - but that is part of a bigger discussion (ex.
I'm saying "asynchronous" as the Lua model is cooperative multitasking (
No,
As the example stands, local v1 is declared as a local variable in the QA fil, on top-level.
self.v2 gives and error, as self is not defined on top-level. 'self' is only defined inside metods (object:method(...))
self.v3 creates a new key-value pair (v3 = 3) in the QuickApp object. You can think about self as a Lua table where you can lookup keys where some are bound to values and other to methods...
It's much faster to access a local variable (v1) than it is to access a key in a Lua table (v3)
Protected timer fun with pcall...
    Well, I appreciate your explanation, I've learned some again.
    One cogitation: the time someone spent doing something for you, you can refund with money. But engagement, availability and will to share of knowledge cannot be simply paid - a gratitude for all this you do for us, Jan.
    Inspire by above I made small test:
    And the results (on the HC3):
    14x slower. Worth remembered. Tested the same with VSC and emulator on 9 years old mac gives result of ~15 sec, similar for both type of variables.
